Requiremets for integration IP-PBX with SIP Trunk
daru ban
Hi, all!
I'm looking for the requirement of sip trunk integration of PBX.
I want to know the sip message for transfer with original ani upadate.
Example:
PSTN --- IP PBX --- SIP Trunk --- CUCM
Phone A is in IP PBX and Phone B is in CUCM.
Phone A receives PSTN calling(03-ABCD-EFGH), after talking Phone A transfers the call to Phone B(Attendee transfer) and Phone B talks with PSTN caller then Phone B displays original ani as 03-ABCD-EFGH.
In this exmaple, what SIP message does IP-PBX need to send to CUCM?
What document does indicate these requirements?
Jonathan Schulenberg
I’m not aware of a prescriptive Cisco document that answers the question as you have posed it. This is mostly a generic SIP RFC3261 question; the IP PBX would need to send the identity information in a SIP header, most commonly P-Asserted-Identity (PAI) from RFC3325.
The exact message that is conveyed in depends on the behavior of the IP PBX. For example, the PAI header for the consult call leg would likely be phone A. When the transfer is completed, I would anticipate a reINVITE with an updated PAI header depicting new connected party information.
The great thing about SIP is that it’s all plain text and easily readable. Pull traces or a PCAP of a call and just read through the SIP dialog to see what happens.
