Reset Unity Connection 2.0.1 Business Edition Administrator Password
jalmanza_82
The unity connection 2.0.1 installed in a Business Edition server its admin password can be reset ?
Hi Joel,
I wouldn't think a reboot would be necessary. If the password works and allows you to log into the ccmadmin pages but not the UConnadmin pages, you may be running into CSCsh98940. Try the workaround suggested for this defect and see if that resolves it for you.
Michael.
6 Replies 6
Michael Owuor
Joel,
From the CLI, use these commands:
utils reset_ui_administrator_password
utils reset_ui_administrator_name
The administrator password applies when logging into either the CCM admin or Unity Connection admin pages.
Michael.
thanks Michael, Do I need to reboot the sever?
Because I do those commands , and I still cant enter admin pages of the Unity Connection, though the CallManager works fine.
thanks for the help
Hi Joel,
Michael.
Thanks for the info.
The issue is solved
Michael Owuor
Joel,
Michael.
Thanks for the update Joel.
Cheers!
Michael.
