Restore default greeting for system call handler
craig.petty
Unity Connection 8.0.3
There is a default system call handler called "Opening Greeting".  A while ago I changed the greeting for that call handler without first saving a copy of the default greeting, and now I want to revert it to the default.  How can I do that?
I think the default greeting said, "Hello, Cisco Unity Connection messaging system.  From a touch tone telephone you may dial an extension at any time.  For a directory of extensions press 4, otherwise, please hold to leave a general message".
Rob Huffman
Hi Craig,
Have you tried just disabling your "recorded" greeting? I would think that should reinstate the default.
Cheers!
Rob
Thanks.  Unity Conn won't let me disable the standard greeting, but I can change it to "Callers Hear: System Default Greeting" instead of "My Personal Recording" which I have it set to now.  I assume that's what you meant.  Yes, I did try that, but then I hear, "sorry opening greeting is not available", so that's no good.
