Ringing incoming calls on multiple phones
mike
Hi all,
After a lot of hours of research, I have decided to post my question here as I believe I have confused myself more trying to figure this out on my own.
Here is the situation...
I have a client that is using at Cisco 2851 Router with CME 7.1 and Unity Express 7.0. They have multiple phones. The way it's setup right now is all incoming calls to the main line will ring on the receptionist phone. If it's not answered or it's busy, it is set to forward to another extension. They currently are running without a receptionist and am needing to make a couple of changes until they get someone hired. They want the reception phone to ring twice and if there is no answer, it forwards to 2 different extensions simultaneously and rings both phones. Then whoever of the two is available will be able to take the call. I am sure there is a way to make this happen, I'm just not sure how. I am needing some help. Is there somewhere in Unity that I can do this? Or is it only through CLI? Either way is fine with me. I am just not familiar with the telephony side of Cisco. I have been able to take care of just about all of their issues till now.
Mike
Hey Mike,
No worries my friend!
What I meant (although poorly written and explained) is that hopefully
there is a "Spare" line button on each of Kay and Lori's phones. Create a new DN
let's say it's 455. Add 455 to the spare button on each phone and change the "Main"
phone as follows;
ephone-dn  1  dual-line
number 500 secondary 5551234567
label Main Number - 500
description 5551234567
name Main Number
call-forward max-length 4
call-forward busy 598
call-forward noan 455 timeout 6
corlist incoming Call-InternalLocalLongDist
Does this make more sense?
Cheers!
Rob
5 Replies 5
Rob Huffman
Hi Mike,
For a very quick and simple solution, I would recommend just adding
a new DN (target-number) to the "Backup" phones. Then configure the Forward No Answer
on the current reception phone to point to this "new" number and roll over
after two rings
call-forward noan
To configure call forwarding so that incoming calls to an extension (ephone-dn) that does not answer are forwarded to another number, use the call-forward noan command in ephone-dn or ephone-dn-template configuration mode. To disable call forwarding, use the no form of this command.
call-forward noan target-number timeout seconds (*set the timeout seconds to 6 for two rings)
timeout seconds - Sets the duration that a call can ring with no answer before the call is forwarded to the target number. Range is from 3 to 60000. There is no default value.
From this good CME doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_c1ht.html#wp1063669
Cheers!
Rob
Hi Rob,
Thanks for your quick reply. I also like the link you sent. Through all of the hours of research I was doing, I never ran across that doc.
I am still a little confused about your first sentence..."For a very quick and simple solution, I would recommend just adding
a new DN (target-number) to the "Backup" phones." I am not sure what that means exactly.
Here is what I currently have for dns below. Ephone-dn 1 is the reception line. I need it to forward to ephone-dn 3 and 12.
name Main Number
call-forward noan 598 timeout 15
ephone-dn  3  dual-line
number 515 secondary 5552345678
label Kay Smith - 515
description 5552345678
name Kay Smith
call-forward busy 1000
call-forward noan 1000 timeout 15
hold-alert 30 originator
ephone-dn  12  dual-line
number 543 secondary 5553456789
label Lori Jones - 543
description 5553456789
name Lori Jones
call-forward busy 550
call-forward noan 1000 timeout 20
My understanding of your first sentence is to create a new ephone-dn number and associate the two extensions I want forwarded? Or am I way off on that. Am I making it harder than what it should be?
Thanks for your help with this.
Mike
Hey Mike,
phone as follows;
name Main Number
Cheers!
Rob
Thanks Rob,
I believe I am starting to understand.
I should be able to create a "dummy" ephone-dn, for example...
ephone-dn  51
number 455
park-slot timeout 120 limit 4
Once that is created, I can then program one of the overlay buttons on there phones to that number 455 and set it to normal ring. Once that is done, it should then forward the calls to both of their phones at the same time. Then whoever answers it obviously gets the call.
I will give this a go and let you know how it turns out. I really appreciate your patience with me on this as well as your help.
Mike
THANK YOU ROB!!
I went in and created a dummy dn and setup a button on each of the phones to forward to that newly created dn with normal ring set. I just called and it all worked.
I have marked your last post as the correct answer.
I appreciate all your help and your patience.
Have a great day!
Mike
