Route incoming calls out to several external numbers
ckgilliam
I`m looking for a way to have users call in to a number and then route that call out to several external cell phones without any prompts or menus just route the call out.
6 Replies 6
Jaime Valencia
You need to mention what you have to work with, call control agent, version, etc. and not just want you want to achieve...
java
if this helps, please rate
ckgilliam
Yes, my bad. BE6k. Call Manager, Unity, UCCX verson 9. Today calls coming into number 800xxxxxxx are routed to several cell phones and this routing takes place on a cloud based pbx that is going away. Now need same capability using Call Manager.
With CUCM the only option would be a line group and have the members use SNR, not too sure if you could write down a UCCX script for that.
java
Ok so basically creat a DN for each person then would you do SNR or could you just do a forward all?
Any call forward on the phone is ignored if the call arrives via a line group, SRN is the only option.
java
Will SNR work if these users don`t have a phone/device to build it off of?
