10-09-2016 11:38 PM - edited 03-19-2019 11:40 AM
Hi all,
how can I determine why it takes some minutes if I open Message Details in the Call Flow Diagram in the RTMT tool?
CPU is not increased during that opening.
Yes, notorious I get the warning low water mark exceeded.
My VMWare admins monitored if CPU or storage were busy which it did not.
Cluster Restart or RTMT on a diferent machine did not helped.
Can someone help? Monitoring is a pain.
10-09-2016 11:50 PM
Hi Paul,
Which RTMT and cucm versions are involved? Which OS is the RTMT installed on? Do you experience the same issue when you connect a laptop with RTMT installed in the same site/subnet as the cucm server?
Manish
10-09-2016 11:59 PM
Hi Manish,
RTMT 11.0(001)
UCM: 11.0.1.21017-1
I use RTMT on my Win7 Management PC but I also experience the same issue on a Win7 VM in the UCM subnet.
10-10-2016 12:07 AM
10-10-2016 12:59 AM
Thanks Manish,
I hoped I can avoid engaging the TAC.
