Sama
samamallareddy
I need help in ISDN-E1 connectivity Bitween CUCM V7.0 and Siemens HiPath 4000 V5.0.
Recntly we have connected ISDN-E1 connectivity bitween CUCM V7.0 and Hipath 4000 V5.0 through ISR 3845 Gateway. when we make call from siemens to cisco its working fine,but from cisco to siemens not working.when i checked in debug trace it says " 0X86b Incoming calls Barred" please find below gateway configuration.
CM-E1-GW#
CM-E1-GW#sh run
Building configuration...
Current configuration : 2398 bytes
version 12.4
hostname CM-E1-GW
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
card type e1 0 1
logging message-counter syslog
enable secret 5 $1$F6R7$4FNy4gbwAVMR8c.b/VgER0
no aaa new-model
network-clock-participate wic 1
dot11 syslog
ip source-route
ip cef
no ip domain lookup
ip host CM_biccm 192.168.12.50
no ipv6 cef
isdn switch-type primary-5ess
voice-card 0
dspfarm
dsp services dspfarm
archive
log config
  hidekeys
controller E1 0/1/0
pri-group timeslots 1-31 service mgcp
controller E1 0/1/1
interface GigabitEthernet0/0
ip address 192.168.12.55 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-qsig
isdn incoming-voice voice
isdn bind-l3 ccm-manager
isdn channel-id invert extend-bit
no cdp enable
interface Serial0/1/1:15
no ip address
encapsulation hdlc
no cdp enable
ip default-gateway 192.168.12.254
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 192.168.12.254
no ip http server
no ip http secure-server
control-plane
voice-port 0/1/0:15
echo-cancel coverage 64
voice-port 0/1/1:15
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server CM_biccm
ccm-manager config
mgcp
mgcp call-agent 192.168.12.50 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp default-package mt-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 ecm
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp behavior g729-variants static-pt
mgcp profile default
line con 0
line aux 0
line vty 0 4
password biccm
login
scheduler allocate 20000 1000
end
CM-E1-GW#
Not working Call from cisco to siemens
CM-E1-GW#terminal monitor
CM-E1-GW#
*Oct 16 08:27:25.693: ISDN Se0/1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0002
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Facility i = 0x9FAA06800100820100A1080201000201008400
        Calling Party Number i = 0x0081, '2303'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '1198'
*Oct 16 08:27:25.741: ISDN Se0/1/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x
8002
*Oct 16 08:27:25.765: ISDN Se0/1/0:15 Q931: RX <- PROGRESS pd = 8  callref = 0x8
002
        Cause i = 0x80B6 - Incoming calls are barred
        Facility i = 0x9FAA068001008201008B0100A10F0202B5B702015530068204061C084
        Facility i = 0x9FAA068001008201008B0100A1090202B5C60201038400
        Progress Ind i = 0x8088 - In-band info or appropriate now available
*Oct 16 08:27:34.801: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0
x0002
        Cause i = 0x8090 - Normal call clearing
*Oct 16 08:27:34.877: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x80
02
*Oct 16 08:27:34.893: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x0002
Working Call from siemens to cisco
CM-E1-GW#
CM-E1-GW#
*Oct 16 08:28:27.353: ISDN Se0/1/0:15 Q931: RX <- SETUP pd = 8  callref = 0x0049
                Standard = CCITT
        Channel ID i = 0xA98385
                Exclusive, Channel 5
        Facility i = 0x9FAA068001008201008B0100A10F0202B8D2020155300682040640084
        Facility i = 0x9FAA068001008201008B0100A1180202B8E1020100A10F040A53414D4
1205245444459020101
        Calling Party Number i = 0x0083, '1199'
        Called Party Number i = 0x81, '2303'
                Plan:ISDN, Type:Unknown
        High Layer Compat i = 0x9181
*Oct 16 08:28:27.365: ISDN Se0/1/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x
8049
*Oct 16 08:28:27.365: ISDN Se0/1/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x8
049
        Facility i = 0x9FAA06800100820100A111020101020101800953414D412043495043
*Oct 16 08:28:32.393: ISDN Se0/1/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x80
49
        Facility i = 0x9FAA06800100820100A1080201020201028400
        Connected Number i = 0x0081, '2303'
*Oct 16 08:28:32.465: ISDN Se0/1/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref =
0x0049
*Oct 16 08:28:35.889: ISDN Se0/1/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0
x8049
*Oct 16 08:28:35.965: ISDN Se0/1/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x00
49
*Oct 16 08:28:35.985: ISDN Se0/1/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref =
0x8049
paolo bevilacqua
Your debug show a normal call that is then teardown by the PBX side. Not a call barred message.
In either case, you have to ask to the PBX tech why that happens.
Hi Paolo,
Thanks for the reply. Here i missed something to inform you that, we have ISP-ISDN PRI Lines on Siemens Hipath for External calls usage. when i called from cisco extension to out side(External) call we are able to call( call  is going through siemens ISDN PRI lines).
Here the problem is that only internal calling bitween cisco to hipath.
Kindly send me if you have any document about this.....
Sama
Somebody can Help me on this problem .................
I have deadline to finish the same.................
I found the error for the above problem. it is something relates to ISDN Number type mismatch bitween cisco gateway and hipath 4000.
Can somebody help me in configuration change for Number type in IOS gatway.
thanks
