SFTP Problems with Unity Connection
bskemme
I'm running into the issue that Unity Connection will not backup using freeFTPd as the backup server with files over 1 GB (my mailstore is just over at 1.2 GB).  I've tried setting up one of the recommended servers, Openssh and cygwin, but my problem is that I can't find any documentation on how to setup these servers to allow storage to a remote filesystem.  I can get them to work on the local storage, but due to our company backup strategy I need to have these go to a remote server.  I would rather do the backups directly to this storage instead of setting up a job to copy later.  Has anyone successfully implemented openssh, cygwin, or copssh to drop into a remote fileshare?
Wilson Samuel
Level 7
Level 7
Did you find the solution yet? I have been trying to do the same but little success.. yet
will keep you posted, if  I find the solution :-)
Not yet...right now I am just copying the files over to the remote server via a secondary scheduled task.  Not what I want, but it is all I can do without purchasing the Titan FTP product Cisco recommends.
jerrybaker1
I'm having the exact same issue. Trying to learn Cygwin right now.
