Shared SCCP and SIP line not working
I am attempting to share one extension (2001) on both SIP and SCCP phones using call manager express.
7940 (SIP): with 2 lines
1. ext. 2001
2. ext. 2003
7965 (SCCP): with 2 lines
1. ext. 2001
2. ext. 2004
IPC (SCCP): with 2 lines
1. ext. 2001
2. ext. 2005
It seems when an incoming call comes from my Service Provider's sip trunk, it'll ring the 2001 on the dial peer to register last (So sometimes SCCP, sometimes SIP).
If I dial 2001 from the SIP phone it'll ring on the SIP device, if I dial 2001 from a SCCP phone, it'll ring on the SCCP phones.  I'm attempting to get it to ring on all 3 devices.  Am I missing something?
# SIP config:
voice register dn 1
number 2003
name NAME - 2003
label LABEL - 2003
voice register dn 99
number 2001
shared-line
label Main - 2001
voice register pool 1
id mac 0014.A981.6F21
type 7940
number 1 dn 99
number 2 dn 1
dtmf-relay rtp-nte
description PHONE-1
# SCCP Config
ephone-dn 1
call-waiting ring
number 2004
label 2004
description DESCRIPTION
name NAME
ephone-dn 2
call-waiting ring
number 2005
label DN - 2005
name NAME
ephone-dn 99 octo-line
number 2001
label Main - 2001
shared-line sip
no huntstop
ephone 1
device-security-mode none
mac-address F029.2959.1111
type 7965
button 1:99 2:1
ephone 2
mac-address 000C.2921.8BC4
type CIPC
button 1:99 2:2
6 Replies 6
Did you done the below after configuring shared lines?
  1. Create profile on Voice registrar Global and restarted the phone
  2. Create CNF on Telephoney-service and restarted the phone
Response Signature
Yes, have a voice register global that looks like:
mode cme
source-address 10.0.0.9 port 5060
timeouts interdigit 5
max-dn 200
max-pool 42
load 7960-7940 P0S3-8-12-00
timezone 8
voicemail 2000
tftp-path flash:
create profile sync 0001157440423421
auto-register
And have done the following
telephony-service
  create profile
  create cnf
Both Dial Peers are up up
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT KEEPALIVE VRF
20003 pots up up 2001$ 0 50/0/99 NA  <--------------- SCCP dial peer
40001 voip up up 2003$ 0 syst ipv4:10.0.0.100:5060 NA
40002 voip up up 2001$ 0 syst ipv4:10.0.0.100:5060 NA <-- SIP dial peer
SIP Phone shows as registered:
show voice register pool 1
Total SIP phones registered: 1
Hope you did the restart of phones  after creating profile and CNF
Response Signature
Found the solution here:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmebasic.html#task_7642C4D618C04CD28A114F874D377FC9
"SIP shared-line directory numbers are not supported by the Cisco Unified IP Phone 7902, 7920, 7931, 7940, or 7960, or by analog phones connected to the Cisco VG224."
I was waiting for someone to say, why don't you just convert it to SCCP.  Well the reason for that was I was recreating an environment in a Lab.
So now i'm going to reverse the setup, the 7940 is going to be SCCP (and IPC) and the 7965 will be SIP.
Hope reversing the setup would work.
I have done with 78XX and 79XX.
Response Signature
coult45usmc
Apparently this is not supported in CME with analog phones connected to NIM-4FXSP either. I used stcapp to set them up so they are ephones. (I'm not aware of any other way). The analog phones worked great until I decided to set them up with shared-line sip. After configuring, things seem fine until you actually call the shared line. Then, the analog phones no longer have dial tone nor can they make calls. Yes, I did 'create profile' and 'create cnf-files'. Bummer.
voice register dn 7
number 2001
call-forward b2bua busy 9999
call-forward b2bua noan 9999 timeout 18
shared-line max-calls 4
voice register pool 4
busy-trigger-per-button 5
id mac D4AD.71FA.77DC
type 8865
number 1 dn 7
dtmf-relay sip-notify
codec g711ulaw
video
ephone-dn 7 octo-line
number 2001
call-forward busy 9999
call-forward noan 9999 timeout 18
shared-line sip
no huntstop
ephone 9
mac-address A7D3.911F.0080
max-calls-per-button 2
type anl
button 1:7
I'm finding that I lost a lot of functionality/capabilities by upgrading from CME 12 to 14 and moving from SCCP to SIP phones. Cisco decided to stop making SCCP IP phones and go pure SIP, which is fine, but they still require you to configure things like stcapp, conferencing, paging etc. under telephony-services (in CME). I'm running into compatibility issues between SIP phones configured under voice register global, and features configured under telephony-services. I've not been able to get mixed (SCCP/SIP) hunt groups to work properly for example.
