SIP Dial-Peers on Skinny SRST
j.a.m.e.s
Level 4
Level 4
All,
Does anyone know if it's supported to use SIP dial-peers on a router which is registering SCCP phones for SRST/fallback?
I normally run H323 to send the calls up to an H323/ISDN gateway in the same branch, but we recently migrated this to CUBE - I'd prefer to run SIP on the upstream dial-peers.
James.
j.a.m.e.s
Level 4
Level 4
I have deployed it (admittedly on an old C3800 gateway) with SIP dial-peers towards the CUBE and the SRST call-manager-fallback for skinny phones.
I wasn't onsite and only had a short test window (someone else travelled briefly to the site to test). Certainly outbound calls were working and inbound calls are matching the appropriate dial-peers and generating ringback. I can't be completely sure, but I will post again on this thread if I get the opportunity to test.
