SIP IP phone 7945 not registering on CME 14.1
markmarvinq
Hi, all ip phone 7945 is not registering on CME 14.1 on SIP, while other ip phone like 8821/8841 are getting registered. ccsip message shows SIP/2.0 401 Unauthorized
Tried to delete ITL file on cisco but the phone hang and restarted.
Appreciate your support.
Thank you.
Phone Config:
voice register dn 60
number 6960
name User Operator
label User Operator
voice register pool 60
busy-trigger-per-button 2
id mac 1C1D.862F.0468
type 7945
number 1 dn 60
no digit collect kpml
dtmf-relay sip-notify
voice-class codec 1
username 6960 password Us6960
Debug ccsip messages:
000702: May 26 07:59:38.419: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:10.20.60.30 SIP/2.0
Via: SIP/2.0/UDP 10.180.60.29:5060;branch=z9hG4bK9be11579
From: <sip:6960@10.20.60.30>;tag=1c1d862f046800185e98d1d3-7243f6e5
To: <sip:6960@10.20.60.30>
Call-ID: 1c1d862f-04680017-871d1bbf-0ad067f1@10.180.60.29
Max-Forwards: 70
Date: Sun, 26 May 2024 07:59:14 GMT
CSeq: 122 REGISTER
User-Agent: Cisco-CP7945G/9.3.1
Contact: <sip:52F756C2-C54@10.180.60.29:5060;transport=udp>;+sip.instance="<urn:uuid:00000000-0000-0000-0000-1c1d862f0468>";+u.sip!devicename.ccm.cisco.com="SEP1C1D862F0468";+u.sip!model.ccm.cisco.com="435"
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-6.0.0,X-cisco-xsi-8.5.1
Content-Length: 0
Reason: SIP;cause=200;text="cisco-alarm:14 Name=SEP1C1D862F0468 Load=term45.default Last=cm-closed-tcp"
Expires: 3600
000703: May 26 07:59:38.421: //66019/ADF54D95B225/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <sip:6960@10.20.60.30>;tag=5334DE4A-410
Date: Sun, 26 May 2024 07:59:38 GMT
Server: Cisco-SIPGateway/IOS-17.3.5
CSeq: 122 REGISTER
WWW-Authenticate: Digest realm="all",nonce="6228361E0851FC95",algorithm=MD5,qop="auth"
Content-Length: 0
000704: May 26 07:59:42.419: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Max-Forwards: 70
CSeq: 122 REGISTER
Content-Length: 0
Expires: 3600
000705: May 26 07:59:42.421: //66019/ADF54D95B225/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Sun, 26 May 2024 07:59:42 GMT
CSeq: 122 REGISTER
Content-Length: 0
5 Replies 5
Could you please share the configuration of the voice registrar global  or the full CME config, omitting any IP details?
Response Signature
Does the phone register if you remover the username/password on the voice register pool?
Maren
markmarvinq
@Nithin Eluvathingal , Please find attached config file and additional logs.
@Maren Mahoney , Tried to remove user and pass but still not registering.
You need to have the username and password on the voice register pool as you have configured "authenticate register" on Voice register global. Add the username and password, and also remove the authentication realm all. It’s been a while since I worked with CME, I believe it’s not required.
Next, issue the command create profile and try to register.
Response Signature
markmarvinq
tried to remove authentication realm, but still the same.
