SIP outbound call limitation
mohammad saeed
Level 5
Level 5
Hi guys,
I bought one sip lines from ISP contains 300 lines DID/DOD but I want to know if there is a limitation in cucm 8.6 if 100 lines or more want to call outside together at the same time. Is there any SIP call limitation in Cisco voice system?
Thanks for all
Mohammad Saeed
9 Replies 9
Terry Cheema
There is no limit from CUCM. If you have 300 SIP channels/lines - you would be able to dial to utilize all of the 300 channels, provided:
1) You have enough bandwidth
2) You have enough licenses on your SBC (if you use one)
CUCM will not limit the number of SIP calls.
-Terry
Please rate all helpful posts
What about the CUBE is there any limitation because I heard there is a sessions can buy it to increase the the number of calls?!
Is that correct?
The only limitation is the processing power for the platform, there is no session licenses if thats what you mean.
JB
What is it mean by sessions (Unified Border Element Enterprise License - 5 sessions)?
this is for CUBE 2920 Voice router
Those are paper licenses which means you dont have to install it on the device itself, CUBE licenses are RTU(Right to use) again platform decides the capability.
Also see below for details.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-cube-licensing.html
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/software-activation-on-integrated-services-routers-isr/white_paper_c11_556985.html
JB
Below link would provide you more details regarding the session capability for different platforms CISCO provide
**When using a SM to NIM adapter card for each Service Module slot to turn it into an additional NIM.
Table 9.       CPU Performance on the 4300 and 4400 Series Unified Communications Routers*
Cisco ISR Platform
4321
4331
4351
4431
4451
VoIP Performance: Maximum # of Simultaneous Calls (not exceeding 75% platform CPU usage)
Cisco Unified Border Element
100
500
1000
3000
6000
Standalone Unified Communications Router1
No encryption
100
500
1000
3000
6000
SIP TLS with SRTP
100
500
1000
3000
6000
H.323 Signaling in IPsec with SRTP
100
500
1000
3000
6000
H.323 Signaling and media in IPsec
100
500
1000
3000
6000
WAN Edge Gateway2
No encryption
100
500
1000
3000
6000
SIP TLS with SRTP
100
500
1000
3000
6000
100
500
1000
3000
6000
100
500
1000
3000
6000
WAN Edge Gateway with Compressed Real-Time Protocol (CRTP)3
No encryption
100
500
1000
3000
6000
SIP TLS with SRTP
100
500
1000
3000
6000
100
500
1000
3000
6000
100
500
1000
3000
6000
1 Gigabit Ethernet or Fast Ethernet egress; no quality-of-service (QoS) features; voice traffic only
2 T1/E1 or High-Speed Serial Interface (HSSI) serial egress; some QoS features; voice and small amount of data traffic
3 T1/E1 or HSSI serial egress; some QoS features; CRTP; voice and small amount of data traffic
Table 10.     CPU Performance on the 2900 and 3900 Series Unified Communications Routers*
Cisco ISR Platform
2901
2911
2921
2951
3925
3945
3925E
3945E
VoIP Performance: Maximum Number of Simultaneous Calls (not exceeding 75% platform CPU usage)
CUBE
100
200
400
600
800
950
2100
2500
No encryption
100
150
240
400
720
960
600
840
SIP TLS with SRTP
100
150
240
400
720
880
600
840
100
150
240
400
720
780
600
840
100
150
195
325
360
385
600
840
WAN Edge Gateway2
No encryption
100
150
240
400
610
650
600
840
SIP TLS with SRTP
100
150
240
400
600
645
600
840
100
150
240
400
530
565
600
840
100
125
145
235
265
285
600
840
No encryption
100
150
240
400
510
550
600
840
SIP TLS with SRTP
100
150
240
400
500
540
600
840
100
150
240
400
445
475
600
840
95
105
120
200
220
240
600
840
VoIP Performance: Maximum Number of Calls per Second (not exceeding 75-percent CPU)
30
35
Notes:
  1. All results represent G.729A or G.711 (20-ms packetization) switched H.323 calls with VAD turned off.
  2. The call success rate (CSR) of all tests is 98 to 100 percent.
  3. Call duration of tests is 180 seconds except for calls-per-second rate testing, where the duration is shorter. The test release is Cisco IOS Software Release 15.0.1M for Cisco 2900 and 3900 ISRs. For the testing of the Cisco 4400, Cisco IOS XE Software Release 3.10 was used. This document contains general numbers as a guide to the approximate performance of the unified communications routers. The numbers are extrapolated from a large number of disparate tests, test conditions, and traffic patterns. Several nontesting factors have also been accounted for. Therefore, actual test results will vary, and we encourage you to do proof-of-concept testing for more specific performance numbers for a specific scenario, traffic pattern, or release.
http://www.cisco.com/c/en/us/products/collateral/unified-communications/tdm-gateways/data-sheet-c78-729824.html
JB
But it means 5 sessions is available for this CUBE if I need more sessions I have to buy licenses! Right?
No, this is what i am trying to explain they are just paper licenses, they do not restrict sessions in any way.
JB
Look at the below discussion it might help.
https://supportforums.cisco.com/discussion/11035831/cube-licensing-29xx39xx-routers
JB
