Smart Licensing Authorization Expired
campbech1
We have run into issues with our CUCM environment with Smart Software Licensing showing "Authorization Expired".
Ok to deregister this from the onsite Satellite and register this?
Any impact to production?
Thank you in advance!
Jaime Valencia
You can try to renew authorization, or try to de-register and register again, as long as you're still within the licensing grace period you won't see any changes, if you already ran out of grace period, you will lose MACDs while it's not registered.
java
if this helps, please rate
