SNR Config two DN's to go to same remote number
I have a directory number (extension) that uses SNR to forward to a remote destination number. I tried to configure a different directory number to behave the same way, but I got an error saying "add failed. The specified remote destination already exists".
2 Accepted Solutions
Brandon Buffin
Configure a single remote destination profile with a single remote destination. On the remote destination profile, associate both DNs.
Brandon
Make sure the DNs/partitions in the remote destination profile match those of the DNs configured on the physical phones.
6 Replies 6
Brandon Buffin
Brandon
I tried to associate both in remote destination profile.
In remote destination I have both extensions in the upper left and both line associations are checked.
In remote destination profile I have both line associations on the top left under association. One of these is "in internal" and the other is "no partition". I also have 2 names and 2 destinations under associated remote destinations.
I have it working on DN 166, but I can't get it to do the same thing on 130.
If you need more info let me know what I should add. Any tips are appreciated.
130 doesn't have a physical phone. It's only on line buttons of some user's phones. Does that matter?
Needs to be in the same partition as the one configured for this DN on these phones.
Thanks a ton, Brandon. That did the trick.
