08-03-2011 02:10 AM - edited 03-19-2019 03:22 AM
Can anyone enlighten me how to backup all the speed dial list of each phone from 4.1 callmanager to 7.1 callmanager ?
08-03-2011 05:47 AM
Hi Alan,
If you are using DMA (Data Migration Assistant) to facilitate this migration
then the Speed Dials,Fastdials and PAB are carried over
https://supportforums.cisco.com/message/1096323#1096323
Cheers!
Rob
08-03-2011 06:06 AM
If there is another way, without using DMA ?
08-03-2011 06:56 AM
Hi Alan,
The only other way that I can think of would be to use a BAT Export from 4.x
and then BAT Import into 7.x. The header fields won't match exactly between
the old/new versions of BAT, so some re-jigging will be required
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/5_0_4/t03phexp.html
Cheers!
Rob
08-03-2011 07:56 AM
If you use the bat method, watch for commas in the labels. These will throw off the comma separated files export/import files.
