SRST 8.6 question
gmckay2e2
I had previously thought that IOS 15.x was a mandatory requirement for 8.6 SRST routers. I have been advised that it's only madatory for CME-as-SRST and that 12.x will be fine for SRST (good news), but it is recommended. I know also there are minimum memory requiremnts for IOS 15.x, specifically 64MB Flash/ 512MB DRAM.
At the same time there are "recommended" memory requirements for SRST 8.6 of 128MB/ 1GB, though this actually again for CME and may not be strictly true for SRST?
My question is, as the 2800s are EoS and I don't want to look at grey market memory, if my memory looks under-powered vs the recommendations for SRST, would I be better sticking with IOS 12.x than upgrading to 15.x which I assume will be more memory intensive?
Thx
Chris Deren
Correct, if you do not have enough memory then you cannot upgrade.
HTH, please rate all useful posts!
Chris
Chris Deren
Chris
Thanks again Chris; very helpful!
