01-27-2015 11:16 PM - edited 03-19-2019 09:06 AM
Has anyone Configured SSO for Jabber successfully with CUCM 10.5 Version.
I am getting following error after Exchanging Meta Data with ADFS Server.
Can anyone suggest further troubleshooting steps. Of if there is any detailed guide for SSO with jabber please advice.
Solved! Go to Solution.
01-29-2015 10:08 AM
You may verify your configuration from the below guides. There are sample configurations.
01-29-2015 10:08 AM
02-14-2015 10:54 PM
Hi Nirmal,
Thanks For the Guides.
Basically the issue was simple , pop up was blocked by my browser so i was unable to see the SSO log in pop Up Window lol ....
