Staff taking too long on their phones.
nickolaskoiser
We recently deployed a Cisco Unified Callmanager for a client in town.
Its working okay but i have a problem:a number of staff are 'overusing' the facility-some staff are talking on the phone for extensively long periods of time-some even engage their phones for upto 4 hours-due to the CAC and AAR configurations some calls either end being dropped or channeled through the PSTN.
If i can find a solution where i can set the talk time to may be a maximum of 30 minutes then I'll be okay.
All am asking for is some guidance on setting the maximum talk time,it can even be better if i can have a solution for interbranch calls(limited) and unlimited for the HQ where bandwidth is not a problem.
Thank you.
Nick.
Tim Smith
Level 4
Level 4
No easy out of the box solution here.
My suggestion would be to use the old fashioned people approach.
Configure CDR. Give your managers / team leaders / supervisors access to their teams lines.
Check reports for excessive calls.. take appropriate people level action.
You can also buy 3rd party products to monitor CDR, and set business rules / alerts etc to assist with this.
Also check the calling priviliges of people and adjust if possible.
Cheers,
Tim.
allan.thomas
Level 8
Level 8
One alternative would be to change the maximum call duration, however this is applicable to all phones.
Within the CallManager service parameters, there is a maximum call duration timer service parameter, this also controls the maximum conference duration.
The default is 720 minutes, so you could change this to something more appropriate. As I said this is applicable to all Phones, so 30 minutes may or may not be practical?
Rgds
Allan.
Pls rate helpful posts.
