tcl ivr api - connection command with IP to IP
tbacon
In the command reference
Connections between two IP legs are not supported. Even if the command seems to execute successfully, it actually does not work. Doing so could potentially cause problems, as there is currently no way to capture the resulting error at the script level. Therefore, it is advisable to avoid attempting such connections.
I just wanted to verify that we still can't bridge two IP call legs?  We have a customer requirement to do so and it looks like we will have to go with CUAE instead.
paolo bevilacqua
I personally believe it would work.
Anyway, considering you are a Cisco employee, I suggest you look for answers using many internal resources, to avoid giving the impression that a you have to a customer forum instead.
