TFTP Firmware upload
Our company have 2 Callmanager Clusters and it's quite hard to keep the phoneloads on both of them the same. The architecture of both clusters are the same:
12 Nodes:
1 Publisher
8 Subscriber (4 Active, 4Inactive)
and 3 TFTP Server -  all Nodes Callmanager Version: 8.6.2.23900-10
This times 2 makes 6 TFTP Servers in total. So if we want to upgrade a phoneload of only one phonetype we have to upload the file on 6 TFTP Servers. So here is my question, is it possible to synchronize the TFTP files between nodes? Or is there a "better"/faster way to upload files on TFTPs?
Cheers for your help.
Best regards,
Matthias
Shadi Shami
Level 7
Level 7
Hello Matthias,
Cisco Prime Collaboration Deployment (PCD) helps.
Thank you,
Shadi
Shadi Shami
Level 7
Level 7
Hello Matthias,
Thank you,
Shadi
you need to upload files on all TFTP servers. There is no such synchronisation of TFTP files between nodes.
regds,
aman
