05-10-2016 11:42 PM - edited 03-19-2019 11:05 AM
Hi, I am new to Cisco CUCM server, I am facing an issue and the issue is
Huntpilot number is XXXX and directory number is YYYY.
when calling on XXXX call is getting failed where as if we call in YYYY call is getting connected and working fine.
Please help me with this.
Solved! Go to Solution.
05-11-2016 12:31 AM
Please double check the basic configuration if not done before;
1. Respective enable hunt list check box is enabled
2. Correct hunt group is assigned to hunt list.
3. YYYY is assigned to hunt group.
4. Reset the hunt list.
5. Under YYYY device page, Logged into Hunt Group checkbox is enabled.
- Vivek
05-11-2016 12:04 AM
Please ensure YYYY is not logged out from hunt group.
- Vivek
05-11-2016 12:10 AM
Hi Vivek,
Thx for your reply.
YYYY is logged in and the device is avaialbe, But not able to connect.
05-11-2016 12:31 AM
- Vivek
05-11-2016 01:58 AM
Ohh Great...!
Thanks Vivek, It's working with the above solution.
05-11-2016 02:00 AM
Thanks for sharing the result.
- Vivek
05-12-2016 05:50 AM
Hi Vivek,
Logged into Hunt Group checkbox is getting unchecked automatically after the first call.
Pls help me with this.
Omkar
05-12-2016 07:03 AM
Please follow the Rob (+5) suggestion which he has just posted.
- Vivek
05-12-2016 06:49 AM
Hi there,
Can you check for this setting on the Line group config;
• If a line member does not answer a queue-enabled call, that line member is logged off the hunt group only if the setting Automatically Logout Hunt Member on No Answer is selected in the Line Group setting window
From;
Cheers!
Rob
