UC caller input
jmccartney1
I have UC 1.2 and am having trouble getting a caller transferred to the proper place using the "Caller input" keys. When a call comes into extension 4200 the caller hears the greeting "Press 1 to be transferred to the User Directory" , "press 2 to routed to the Command Center". If the user presses 2 during the greeting the caller is routed properly, if they wait till the greeting finishes and then presses 2 they hear " I didn't recognize that as a valid entry".
How can I configure this so they are routed properly to the destination I want them to go to?
Thanks.
John
Rob Huffman
Hi John,
This is working as designed. The Caller input is only recognized during
the Greeting. here's a clip;
"Caller input settings define actions that Cisco Unity Connection takes in response to phone keypad keys pressed by callers during a user greeting."
Probably the best you can do here is to either get the recording at 4200 changed to allow enough
time for the caller input choice or on the Greetings page in CUC set the times to reprompt caller
to 1 or more.
Cheers!
Rob
Rob Huffman
Hi John,
to 1 or more.
Cheers!
Rob
Thank Rob,
I changed the greeting (length) and its working fine now.
John
