11-14-2019 05:46 AM - edited 11-14-2019 06:01 AM
Hi there,
I am preparing a plan to migrate UC infrastructure from release 10.5to 12.5. Current systems are in BE6K and new UC will be in Be7K. I have been reading lots of documents for UCM, IM and P, CUC and PCD. But couldn't get a definite answer. Can anyone tell me below approach is good;
The IP address and host names will be change in the new system,
(1)For Call Manager; using PCD
(2) IM and P: I cannot use PCD since the re-addressing is not supported for IM and P;
So what will be the best approach?I cannot use the DRS back up since the new call manager should have the same network settings.
otherwise, I only left with the option to use the DRS back up and restore method in a new isolated network to keep the same IP address and once the restore completed, change the IP new IP
(3) CUC -Migrate cluster task is not supported by PCD
so should I follow the same process outlined for IM&P and use COBRA tool to export and import data.
Note: considered the smart licensing as post-migration task
I highly appreciate it if anyone can shed some light.
Solved! Go to Solution.
11-14-2019 07:30 AM
https://www.youtube.com/watch?v=Kd7dvvP103E
Steps are basically the same on any new PCD release.
Yes, for CUC you would use COBRAS as explained in the CUC upgrade/migration guide.
As you will change the hostname, you'll get new certificates and need to consider ITL.
11-14-2019 07:30 AM
11-14-2019 08:50 AM
Thanks for the response Jaime,
as per your video, you have assigned a new IP address to both call manager and IMP, but the PCD doc says that IP readdressing is not supported. Please find the bottom of the snapshot. Could you please comment
I do have another query that will there be any trust certificate issue with Cisco Phone when it registers with new call manager (new IP and hostname)
11-14-2019 08:56 AM
Yeah, if you use the readdress task. You're talking about a task that is not involved in the migration task.
If you're not familiar with ITL/SBD, spend some time reading the related documentation on the topic as anyone who works with CUCM should be familiar with it.
