05-17-2013 06:33 AM - edited 03-19-2019 06:44 AM
I tried searching for the correct answer but I am having no luck...
Is there a way to tell how many licenses are being used in a UC560?
for example, I I have 80 max licenses, and configured 70 users and 70 phones, however there are only 60 "registered phones"... how many licesenses am I currenly using?
Thank you
Jon
Solved! Go to Solution.
05-17-2013 07:07 AM
Hi Jon,
In your current state you would be using 60 licenses as only
"registered" phones consume a license
Cheers!
Rob
"go easy...step lightly...stay free "
- The Clash
05-17-2013 07:07 AM
Hi Jon,
Cheers!
Rob
- The Clash
