UC8.51 UM features
jeff.singh_2
Level 3
Level 3
For exchange 2007 and exchange 2010 - which services are being utilised for Calendar, UM and TTS ?  Do all 3 just use EWS on the exchange servers or is imap  also required. (appreciate 2007 is not supported yet).
Also is webdav only requirement for Exchange 2003 integration or is imap also used ?
TIA...Jeff
Jonathan Schulenberg
Exchange 2003 is not yet supported so documentation about how that interface will work is not yet public/final. Anyways, yes Unity Connection uses the EWS interface on Exchange 2010, not IMAP.
thanks for confirmation.
It's anticipated that Exchange 2003 will use WebDav.  In any case, IMAP would not be used for UM as this does put messages in the user's Inbox.
Hailey
Please rate helpful posts!
