UCCX 11.5 Question
mclason01
I am upgrading our UCCX HA nodes from 10.5 to 11.5. I worked with licensing@cisco.com to get the 11.5 licenses already.
Here is my question: After the upgrade, do I need to delete the old licenses from the UCCX nodes? Or do I just add the new ones? I looked for documentation on this but found none. I am unable to test this out in a lab because I do not have any spare licenses to apply to a lab.
Thanks so much for any information!
Rajan
As per the upgrade guide, you need to do the following:
"While you are upgrading from a previous release, if there are multiple licenses, zip all the .lic files into a single .zip file and then upload the zip file. If specifying a .zip file, ensure that all .lic files that need to be added are in the root of the .zip file and are not in subfolders in the .zip file."
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/crs/express_11_5/install/guide/uccx_b_uccx-install-upgrade-guide/uccx_b_uccx-install-upgrade-guide_appendix_0110.html
Rajan
Pls rate all useful posts
You do not delete any old licenses.
the upgrade license would provide you with major upgrade while all the feature licenses with existing version remain same.
regds,
aman
Thank you!
Thank you. I would have neglected to combine the licenses if I had not seen this post.
