Unable to access phoneview from phone in unity connection 8.x
rahaman.abdoul
I completely completed phone view config on unity connection 8.x, regarding "Administering Cisco Unity" course, a 2 days course. I activated the appli user with phone 7961g controlled by this user. I also activate phone view in both phone system and user phone menu, near message locator parameter.
My problem is when I login my user, I can press key 5 to search message (message locator feature) but when I want to display messages (key 4) I have the message "invalid selection"...
Why I cannot use this key, since phone view was activated for this user?
Thanks a lot
Rahaman
himherna
Did you solve this issue ? I'm experiencing the same.
That feature is pretty dead now - it was never well implemented.
You would be better to configure 'Visual Voicemail' that doesn't require the hybrid use of the TUI and the phone display; VV just uses a Java Midlet XML app.
Just follow the instructions carefully; e.g. use all the same names for the service etc or it doesn't work.
http://www.cisco.com/en/US/docs/voice_ip_comm/cupa/visual_voicemail/8.5/install/guide/configure.html
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Thanks Aaron,
I understand Cisco encourages to use Visual Voicemail, however it is still well documented in version 8.x
Setup Phone View:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/administration/guide/8xcucsag245.pdf
Requirements for Cisco Unity Connection Phone View:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/requirements/8xcucsysreqs.html#wp87614
I'm interested if somebody with the exact issue has found a workaround to make it work.
Himer Hernandez
Steven DiStefano
