Unable to connect media on CMS/web appilcation
akram.root
Level 4
Level 4
Hello all,
I have a cms 3.0.1, call conference on internal with web application  via PC work fine , also on external call conference web application work fine via mobile , but the  external call conference not work via PC , it give me this message :
Could you help me please to solve this error.
Best regards
Akram
Hello ,
The problem is solved after putting  the ip address of DMZ 1 not of DMZ2 by cms    on  /api/v1/turnServers.
Best regards
For the issue you need to be more specific about the external connectivity into your cms whether its a VPN or through expressway , also u need to check cms logs by doing syslog follow , gather infos from your pc using Wireshark ,check expressway logs if u using it as a turn server for cms.
Finally check this ,it could help you :- https://community.cisco.com/t5/collaboration-applications/webrtc-error-unable-to-cponnect-media-rejoin-meeting/td-p/4176957
Thank you for your reply ,
The external connectivity into my cms  through expressway , when i check the logs of expressway i see this log:
Detail="Not Found" Protocol="UDP" Response-code="404" Level="1
Best regards
Hello ,
Best regards
Which part DMZ issue, firewall site or CMS between expressway e
