Unified Presence 8.6.5 DB replication problem
zhukov
Good day!
After upgrade Presence version 8.6.3 to version 8.6.5.15900-3 and after that changing ip address i have problem with DB replication: status of replication is permanently "0 - initializing". "utils dbreplication clusterreset" doesn't help. It is only one node in the cluster. And all services working fine.
How can i restore db replication process or it is normal situation?
Thank you!
Manish Gogna
As per my understanding it will not matter in a single node cluster, since replication involves sharing database updates between different servers as explained in the following guide for cucm
https://supportforums.cisco.com/document/52421/troubleshooting-cucm-database-replication-linux-appliance-model#Checking_Current_Replication_Status
Manish
- Do rate helpful posts -
