I have a database replication issue with the unitydb database. All of the publications and subscriptions look fine. I have a discrepancy with (at least) the subscribers table within unitydb. The primary server database is 25MB and the failover server database is 74MB!!
I noticed the issue when running dbwalker. I had a few errors that needed fixing on my primary server. When I ran dbwalker on the failover server, it said I had 334 errors!!! The log showed users that have been deleted from the primary server.
I tested replication by adding a hander and the failover server replicated it correctly. My issue seems to be limited to some of the tables within unitydb.
Now for my question...is there an easy way to reinitialize/rebuild the replication between the primary and the failover server?
- Tony
