Unity 4.0 VM Forwarding
jalston45
Hi is it possible to have a Unity 4.0 system, forward VM to multiple subscribers, when a message is left on a group phone?
if the message is left in a call handler set the message recipient as a PDL
javalenc
if this helps, please rate
java
5 Replies 5
Tommer Catlin
I do not think you can forward in that matter. Your options are:
- If using Unified Messaging with Exchange, setup a mail-enabled Public Folder. Associate this alias with the group mailbox number. When the voicemail is left, it will be deposited into the public mail folder you specified.
- Possibly use a server based rule wizard for any voicemail messages, forward to x, y and z.
hope this helps, maybe there are other solutions?
javalenc
java
ahhh... that way.... nice call!
Thank you for your help
Thanks for your help
