Unity 4.04 Failover
kckorb
We currently have on 4.04 server with 300 users and 32 ports and plan on implementing a failover server. What do I need to order ? Is the fail over licenesed by user or ports ? Can I just order a fail over upgrade ? UNITY-FOVRSVR4-32 is this the right product number ?
Ginger Dillon
Hi -
You will also need to order User Failover options, UNITYUM-FOVR-USR for each unified messaging user on the primary server OR UNITYVM-FOVR-USR for each voice messaging user on the primary server. The number you listed is the Software Server Failover option for 4-32 ports. One must be ordered for each processor you will have on the secondary server. If you need further clarification, here is the Product Configurator weblink - http://www.cisco.com/order/apollo/configureHome.html
Type in Unity in the Enter Product Field. In the resulting display, click on the Unity 4.0 hyperlink and you can navigate through the various selections. This is also another good link for ordering Unity - http://www.cisco.com/en/US/customer/products/sw/voicesw/ps2237/products_quick_reference_guide09186a008011c984.html#wp1004595
Ginger
