Unity 7.0(2) Question
shane.orr
Level 4
Level 4
Current:
Unity 7.0(2) (Windows)
Exchange 2007
AD 2008 R2
I plan on migrating to Unity Connection 9.x soon but in the time being we want to start testing Exchange 2013 on non voicemail enabled mailboxes.
Does anyone know if the schema update required for Exchange 2013 to be installed will adversely affect the communication between Unity 7 and Exchange 2007?
davrojas
Level 3
Level 3
Hello Shane,
Unity 7.x with Exchange 2013 is not supported. If the schema changes you are or will be performing do not involve Unity nor Exchange 2007 there should be no issues.
Even if you tested out in a lab environment and get it to work, if it breaks it will be unlikely to receive support on that matter by TAC.
Best Regards,
David Rojas Peck.
