Unity 7.0 Cores with Vpshere client
wpcarmody
Can Vsphere 4.1 coreside on a server running Unity 7.0?
Chris Deren
If you are asking if Unity 7.0 can be virtulized on top of VMware ESXi 4.1, the answer is yes on supported platform, here is reference link:
http://docwiki.cisco.com/wiki/Unified_Communications_Virtualization_Supported_Applications
HTH,
Chris
Chris:
I wanted to know if there would be any known conflicts if i installed Vsphere 4.1 client on an existing Unity 7.0 server and ran Vsphere client from that server to access other vm servers?
No, that is not supported to run it on Unity server. It would surely work, but Cisco TAC will have you remove it if they see it and they are troubeshooting anything.
Chris
