Unity 7.x Auto Attendant
Neal haas
Level 3
Level 3
So far I am 90% on the way to creating a AA. Docs are only for older unity. here is what I have glenned out of many old documents.
Make an AutoAttendant
First Call Manager
1.       Create Non Secure Voice Mail Ports (5)
2.       Create Hunt List, Hunt Group, and Pilot Number, DONE!
Then Unity
1.       Create Port Group (Operator_Auto_Attendant)
2.       Create Ports(5)
3.       Created Call Handler Template Called (County Operator AutoAttendant)
4.       Created System Call Manager (County_Operator_Auto_Attendant) with extension 05956
5.       Call Routing à Direct Routing Rules: Added “Operator_Auto_Attendant” and Parameter “Edit Dialed Number”, Operator “IN” Operand Value 05956.
So is what am I missing?
2 Accepted Solutions
Hi Neal,
You're almost there
You didn't mention what is being played before your intended
recording. If it is "sorry" blah,blah,blah then is usually because the
recording was recorded as the "recorded name" rather than under
the actual Greetings section related to the Call Handler.
Cheers!
Rob
Hey Neal,
You are most welcome (this is a nice description)
From Unity Master Lindborg;
https://supportforums.cisco.com/message/314244#314244
Cheers!
Rob
6 Replies 6
Neal haas
Level 3
Level 3
Opps hit submit to fast.
when I call the number 05956 I get a anouncement before the message, if I press a 1 my calls get transferred as programmed. So how do I just get the AA message????
Hi Neal,
You're almost there
Cheers!
Rob
It says "Sorry" then My Message Then "It is not available . . . ."
So how do I drop the greeting and ending.
OK went to to System Call Handlers, Under Callers Hear Select "My Personal Recording"
Works great!!!!
Thanks for the pointers
One last question, Do I need to record a message under the System Call Handler or can I upload a wav file?
Thanks Rob for your help!
Hey Neal,
Cheers!
Rob
