Unity 7.x failover !!
satishy_2
One of my My customer is running Unity 4.2 on MCS 7835- H1-ECS1 server and planning to upgrade the unity from 4.2 to unity 7.x.
During this process we are changing replacing the hardware also from MCS 7835- H1-ECS1 to MCS-7835-H2-ECS2. As old server can also support unity 7.x so I was wondering I can use it as failover server.
Is there any specific requirement to have same kind of server for the unity failover ?
Satish
Jaime Valencia
As long as they are in the same platform overlay they don't need to be the exact same model
Failover Requirements When the Message Store Is Installed on a Separate Platform
Revised September 4, 2009
Both Cisco Unity servers must appear on the Cisco Unity Supported Platforms List at http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_data_sheets_list.html and must belong to the same platform overlay.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/7x/requirements/7xcusysreq.html#wp472908
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
