Unity 8.0 Cobras and GSM
jrezab
I am using Cobras to migration users from Unity 4.05 to Unity 8.0.
The severs (a) and (b) are networked.  Is GSM compatible with Unity 8.0?
TIA.. Jrezab
Solomon John John
GSM is not supported in Unity 8
Refer: http://www.ciscounitytools.com/Applications/Unity/GSM/GSM.html
--Solo
I saw the chart that indicated no support past Unity 7.x, but if you look in the revision history there is this:
Version 2.02.0001 (2009/08/04) -- Update for UCI Networking in Unity 8.0
That leads me to believe there might be some support for Unity 8.x
JRezab
