Unity 8.0 Installation
bobby.jacob
Hello all,
Iam doing a new installation for Unity 8 without Failover with Exchange 2010 as a partner server.
I had done the OS Installation,done all latest Server updates, latest ES patched, had run the
ExchangeMapiCdo.EXE.
I had completed the Permission  wizard.
When i start the Unity Installation wizard, starting service installation wizard, iam getting an option to chose my exchange version, where i have only Exchange 2003 or Exchange 2007. Iam not getting an option to choose 2010. Is it the way the setup is.?
Bobby
mdfull2
Did you see the 2010 Mailstores in Permissions Wizard?  Did you run the latest version of PW?
Also, do not use the version of ExchangeMapiCdo.exe that came on the Unity DVD.
PW is the latest version i downloaded and used. I saw the exchange2010 mailbox store while running PW.
Also ExhangeMapi downloaded from MS Site.
