Unity AMIS integration question
allan.wells
Level 3
Level 3
Is AMIS integration possible between Unity and CAllexpress voicemail.
Task List: Setting Up Cisco Unity To Use AMIS
Use this task list to set up Cisco Unity to use AMIS. The cross-references take you to detailed procedures for the setup.
I cant find any info from the below link.
1. Verify that the voice messaging system that Cisco Unity will be networked with is listed in the "Supported AMIS-Compliant Voice Messaging Systems" section of the Cisco Unity System Requirements, and Supported Hardware and Software, available on Cisco.com at http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_pre_installation_guides_list.html.
Al
Hin Lee
•Active Voice Repartee
•Alcatel 4635
•Avaya
–Interchange with AMIS-analog Networking Gateway
–INTUITY AUDIX
–Octel 100 Messaging
–Octel 250/350
•Centigram Voice Mail
•Nortel Networks Meridian Mail
•Siemens PhoneMail
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/prod_system_requirements_hardware09186a0080117617.html#wp31997
For the record
Spoke to Cisco SE and they advised installs have been succesfuly implemented with Call express VM and NEC pabx's and Unity through AMIS-A
Allan
