05-18-2009 04:14 AM - edited 03-18-2019 11:03 PM
Is it needed to have SMTP service running on Unity when it works within Exchange ?
regards
Solved! Go to Solution.
05-18-2009 01:49 PM
Hi -
I believe SMTP is installed as part of the IIS suite when you prep the Unity server - IIS, SMTP, and W3SVC. You can go to Unity server control panel - add/remove programs and select the Windows components on the left side of console. Select IIS and you should be able to see the options for components.
Ginger
05-18-2009 06:17 AM
It is installed and running on every one of my Unity servers so I would assume this gets installed by default.
Tray
05-18-2009 06:21 AM
Well, the same on all of mine.
05-18-2009 01:49 PM
Hi -
Ginger
