Unity audio file
Somebody know how to add a new audio file in unity connection?
go to whatever you want to upload the greeting, click on the media bar and there is an option to load files from your PC
java
if this helps, please rate
java
Jaime Valencia
what do you mean??
you want to add a greeting?? a recorded name??
also what verstion are you running?
java
java
a greeting I have the audio file in mi PC, is the version 5.0
java
java
