11-07-2008 03:22 PM - edited 03-18-2019 09:57 PM
Somebody know how to add a new audio file in unity connection?
Solved! Go to Solution.
11-10-2008 07:12 AM
go to whatever you want to upload the greeting, click on the media bar and there is an option to load files from your PC
java
if this helps, please rate
11-07-2008 06:37 PM
what do you mean??
you want to add a greeting?? a recorded name??
also what verstion are you running?
java
11-10-2008 05:51 AM
a greeting I have the audio file in mi PC, is the version 5.0
11-10-2008 07:12 AM
java
