Unity Auto Shutdown (EAAS) initiated due to thermal reason
yewting
The Unity Server auto shutdown due the the following reason:
Event Type: Error
Event Source: cpqasm2
Event Category: None
Event ID: 4111
Date: 1/18/2005
Time: 11:55:16 PM
User: N/A
Computer: UNITY1
Description:
Environment Abnormality Auto Shutdown (EAAS) initiated due to thermal reasons, either resulting from the system overheating, or from the loss of cooling.
Data:
0000: 00 00 00 00 01 00 58 00 ......X.
0008: 00 00 00 00 0f 10 35 c4 ......5Ä
0010: 00 00 00 00 00 00 00 00 ........
0018: 00 00 00 00 00 00 00 00 ........
0020: 00 00 00 00 00 00 00 00 ........
Which part of the server hardware should I check? Need help here. Pls advise. Thank you very much.
kechambe
Level 7
Level 7
It's like that there is a probably with one of the fans but I can't say for sure. If the server is Cisco branded hardware and you have a contact on the hardware you can open a case with TAC and they can get HP involved. Otherwise it would be best to contact HP or whoever supports your server hardware directly.
Keith
Hi Keith,
Thank you for the prompt reply. The server is Cisco MCS 7845. I'll open the TAC case for hardware replacement.
