unity con 8.6 with exchange 2010 SSL requirement
Hello All,
i would like to find out if anyone has any suggestion on how to integrate a unity connection with a CAS server which has ssl enabled.  I guess i will have to download the ssl cert and install it on unity con? if so, where exactly this get installed. is it get installed OS administration security->certificate management? if you can provide me more details on that be great.
we have 2 cas..one with ssl and one without (2 diff sites). my next question is do i have to create 2 unity msg service entry with one pointing to one with ssl and ohter pointing to one without.
i really appriciate for any feedbacks i get.
thanks
vijay
