unity connection 10.5.2 su4a - missing option for exchange 2010/2013/2016 under Unified Messaging Service
unity connection 10.5.2 su4a. fresh install with 5000user ova template.
i don't see option for exchange 2010/2013/2016 exchange or client access server option under unified messaging services to integrate with exchange.  (see attached pic). the last option is exchange 2007 or higher client access server.
however, i have another client with 10.5.2su2a. which has exchange 2007/2010/2013 client access server option.  which is kind of strange because higher version of unity doesn't show those exchange option but lower does.
anyone experienced this?
thanks
vijay
Brandon Buffin
Very strange. SU4 added the option for 2013/2016. I'm guessing if you choose the 2007 and above option it will work. Can you verify?
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/10x/unified_messaging/guide/10xcucumgx/10xcucumg020.html
Brandon
yes i can try but thats not going to give me much confidence to go into production
Jaime Valencia
Support for Exchange 2016 was introduced on SU3
SU4 was supposed to add the option for Exchange 2016 to the interface
11.5(1)SU2 shows the same options.
There should be no problem using the 2007 and above
java
if this helps, please rate
