Unity connection 10.5 fresh installation getting error ks_post.sh error
When we try fresh unity connection in ESXi 6, we are getting  "ks_post.sh" error, please advice on this issues. Screen shot attached for this error.
6 Replies 6
Jaime Valencia
We don't support ESXi 6, the documentation CLEARLY states the supported ESXi version.
java
if this helps, please rate
Thanks for the reply.
As per the URL - http://docwiki.cisco.com/wiki/Virtualization_for_Cisco_Unity_Connection
Unity Connection 10.5 supported in ESXi 6.0, kindly correct me if my understanding is wrong.
Supported Versions of VMware vSphere ESXi = 4.0, 4.1, 5.0, 5.1, 5.5, 6.0
OK, so, this is with no PCD??? As all of your previous posts are all PCD, I assumed you were also using it for this.
java
Unity Connection 10.5 fresh installation in ESXi 6.0, during the installation we are getting the error "ks_post.sh", could you please advice.
Is this the first server in the cluster??
Are you using the Cisco OVA?
Does the HW match the required specs??
Is this a fresh install of 10.5(2)?? or are you using some other media, and installing a patch??
java
Yes we are using cisco OVA as attached for 500 users. Using Cisco B-series server.
It is fresh installation 10.5(2), we are not using any patch
