Unity Connection 2.1.2 to 9.1
anis_cisco
Hello all,
We are planning to upgrade our Unity Connection 2.1.2.1000-380 from MCS to UCS 9.1.
Current MCS Server is MCS-7815-I3
I need to know the path that should i follow to upgrade.
Can i install the same Unity Connection version 2.1.2.1000-380 to UCS, restore the database from MCS & upgrade it to 9.1 ?
If yes what is the upgrade path we have to jump from 2.1 to 9 ?
If not then whats the alternative ?
Jaime Valencia
No, you cannot install anything below 8.x on UCS
You upgrade to 7.x,and then either you keep upgrading all the way to 9, or you use COBRAS
Read the upgrade guides and RNs for all info, everything is on CCO
java
if this helps, please rate
7 Replies 7
Jaime Valencia
java
Hi Java,
Thanks for advise.
I upgraded to unity connection 9.1.2 successfully.
Upgrade path that i follow 2.1.2 (6.1.2) -> 2.1.3 (6.1.3) ->2.1.5 (6.1.5)-> 9.1.2
Hi Anis,
Congrats man. I have the same task to upgrade unity connection from 2.1.2 to 9.1.2 version.
Hardware: MCS 7845H2
CPU TypeIntel(R) Xeon(R) CPU 5140 @ 2.33GHz
Memory4096 Mbytes
Software: 6.1.2.1000-380
Version: 2.1.2
Can you please provide the steps followed to upgrade successfully such as DRS and Cobras tools used.
Hello Ibrahim,
I upgraded unity connection from physical MCS to UCS.
On MCS i had version 2.1.2. I installed the same version on UCS, restore the database from MCS through DRS.
Once data restored, i upgraded to ver 2.1.3 (6.1.3) then 2.1.5 (6.1.5) then installed cop.sgn file & then ver 9.1.2
I didnt use COBRA. If you want to use COBRA u should have Unity connection on 7.X.
Let me know if u have some doubt.
Good luck
Thanks for your prompt response Anis.
Did this approach helped you to restore users, greetings and saved voice mails from 2.1.2 unity connection?
Hello Ibrahim,
Appoligize to reply you late.
Yes it restored Users, Greetings, Voice mail
Hello Anis,
Sorry for delay response to you.
Noted. Thanks for your update.
