Unity Connection 7 and alternate extensions
cris_jimenez
Level 2
Level 2
Hello folks
I have unity connection 7 and a shared voice mail. If I configure multiple extensions on MWI it doesn't lid the light on the phone if I set it to notify the user on the secondary or tertiary extension, only on the primary. it only shows the envelope
Do you know a way to solve this?
Chris Deren
This is a CallManager configuration, check out "Visual Message Waiting Indicator Policy" setting on the Line or to change the default behavior adjust global service parameter of the same name.
HTH,
Chris
Chris Deren
HTH,
Chris
thank you Chris
that worked like charm
have a good day
