Unity Connection 7.x and CUCM 7.x - Passwords and Pins
steigja
Level 3
Level 3
Hello All,
            I have a question about passwords and pins between a unity connection 7.x server and CUCM 7.x.  In regards to passwords and pins.  When a user is created in call manager the password and pin will not be propograted to unity connection 7.x after importing the users via AXL right?  How do I define a default password and pin for users who get imported into unity connection?  Is this done in the user template?  thanks
Jason
Jaime Valencia
Yes
User Templates Password Settings
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/gui_reference/guide/7xcucgrg030.html#wp1051436
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
Yes
java
java
