Unity Connection 7.x Digital Networking
kevin.sullivan
Hello
We are getting ready to istall Unity Connection 7 and would like to know if it is possible to use Digital Networking to Unity 5.x. Can this be done
6 Replies 6
Brad Magnani
Kevin,
This is not possible currently.  UC 8.0 should be offering this new feature once released (believe is later this year).
Hope that helps,
Brad
Thanks Brad,
I need to move users over in phases. Do you know of a way to accomplish this.
Your best bet and probably easiest method would be to use COBRAS to move the users when you need to:
http://www.ciscounitytools.com/Applications/General/COBRAS/COBRAS.html
Brad
I need to be able to forward messages between the Unity Connection and Unity....is there ay way to accomplish this
Thanks Brad
